redrob
Help please i only ahve sound fron 2 speakers not 6
Hi i use to get sound from all six speakers ,but since i moved house last week i can only get sound from 2 of them.
My System is a Windows Vista Home Premium (x64) Service Pack 2 (build 6002)
Install Language: English (United States)
System Locale: English (United States) Gigabyte Technology Co., Ltd. P35-DS3R
Enclosure Type: Desktop
Processor a Main Circuit Board b
2.40 gigahertz Intel Core2 Quad Q6600
64 kilobyte primary memory cache
4096 kilobyte secondary memory cache
High Definition Audio Device
NVIDIA High Definition Audio (4x)
NVIDIA GeForce GTX 460 [Display adapter]
Bus Clock: 266 megahertz
BIOS: Award Software International, Inc. F13 06/19/2009
Drives Memory Modules c,d
245.89 Gigabytes Usable Hard Drive Capacity
62.28 Gigabytes Hard Drive Free Space
Not sure if you need all the crap .
Cheers Rob
What are you using?
Soundcard or onboard?
Digital or Analog?
Best bet would be to go into control panel, then sound, then right click on your audio device and click configure speakers, then set it to 5.1.
Gday mate been a while since we last had a chat ,Im just using the on board sound card ,i have configured the speakers to 5.1 not sure about the digital or analog how do i tell whats what .Thats whats strange because on the configure test all speakers can be heard in the test .
Cheers Rob
Edited by redrob
If all the speakers can be heard in the sound test then there is no problem with your speaker setup (either speakers or soundcard) the problem is with the program you are using the output the sound, if its a game see if it has a surround sound setting or 5.1 setting, if its a media player most likely the audio your listening to is just sterio in which case you need to find the option in the media player that will make it virtual 5.1 or quadraphonic, also if i remember correctly there is an option in sound settings that lets you force virtual surround sound so that it is always on and isnt application dependent.
Personaly i like to leave it in sterio only for music.
What type of receiver do you have? (The thing you plug all of the speakers in to).
You may have to look for settings in various applications and on your receiver. For example in video playback applications, look for Dolby/AC3/DTS pass-through, (your receiver will them hopefully just pick it up, but there might be settings on it too that need changing).
Saving that you might have a mode on your receiver that ups whatever audio it has to whatever it can output to, (i.e., I have an enhanced 7.1 mode that takes stereo etc. and just outputs to all speakers).
Edited by Periander
He has logitech X 530 speakers, they are an all in one system, the sub has the amp for all the speakers in it, you just plug em into your outputs on the PC no receiver nessesary
That'll teach me not to read the thread description.
Edited by Periander
Ok thanks for the reply's guys,that's awesome ,Glad to know i haven't blown up anything ,it only seems to happen when playing some online radio station or music ,so the stereo setting may be the problem ,what is a good program that i can use for playing music online .Is media player no good ,were and how do i change the settings for media player .
Cheers Rob
ill check when i get home where the settings are to force it to use all speakers.
unless someone beats me to it :D
Every time I re-set up my computer and plug the speakers in, I can never get them to work in 5.1 for everything, and can never remember how I make it do it. Same speakers as you.
It will play 5.1 audio in 5.1, but stereo only plays on the L and R speakers instead of being mixed through all of them. It plays through all now, but I can never bloody remember what settings makes it happen.
Actually nope. I have been using solely headphones for the past month, just tried playing music in iTunes, only getting stereo, audio configuration test plays through them all though. Annoying. Video with 5.1 audio does play through all too. Seriously, I've gone through this like ten times.
Thanks harmonic yep your not wrong mate .the pissoff factor is high.
I remember a program that i could tweek depending on the distance the speakers were in the room ,but stuffed if i know where that went ,it use to show a box saying that the plug had been removed.I remember there were heaps of settings to change the sound quality from in a sewer to a stadium .Buggered if i know .
Cheers anyway ,someone will know on here ,as i know there is a wealth of knowledge out there .
G thanks MATE for your pathetic answer,WTF has god got to do with the question in hand ,Fxxx Nose why you even bothered to answer. But that's not the problem if only you read the whole thread.Whose got is shoes .
Thanks heaps to you guys that were a big help its all soughted now with all six speakers working.
The program i meant Harmonic is in the link i sent you, works perfect just click on speaker fill after you click on 5.1 in Realtek HD audio manager.
Cheers Rob
