yiker
Xonar D2x+Logitech Z5500, digital or analogue connection?
I'm going to grab one of these cards soonishly as an upgrade to the onboard I've endured for the last few years.
My useage, when time's free, is probably about 70/30 gaming/music.
Is the best form of connection digital (coax and making use of the Dolby Live! encoding) or analogue i.e 6 channel direct? If the latter is chosen, I take it the ASUS software gives options of how the signal is processed?
From what I gather, analogue is better as the souncard's DAC is of a better quality than the none too shabby Logitech?
Does anyone have the same or similar setup or have any suggestions?
Cheers.
i went and bought a asus xonar DG and i use it with a half decent pair of headphones and the Z2300's, A huge improvement over onboard.
I dont use the coax output just teh 3.5mm jack.
Your reasoning is sound, however i'd still recommend when your new sound card arrives test out both analogue and digital options then use which ever sounds best to you.
Thanks guys.
I'd pretty much decided on that course of action m0zes, just wanted to see whether any members had been there before me.
Now the waiting and anticipation begins :)
Cheers.
