spankdmonke
Monitor Upgrade $300
Asus MX239H
Or is there something better for the same price? and why is it?
Edit: doesn't seem to want to link to the spec page, so its just a picture now
Edited by spankdmonke
Asus MX239H
That Asus looks alright...
But you need to fix your link- it is currently pointing to an LG monitor...
Asus MX239H
thanks. I tried to fix link but doesnt seem to want to go to spec page.
Think its worth going an extra $100 over the $200 monitors?
Is 5ms bad for gaming? e.g. Starcraft 2, Skyrim
Does this monitor go over 75hz for gfx cards?
Im also hearing hype for Dell 2412M but cant seem to find any
http://www.youtube.com/watch?v=vptvPJir50A
wow... did that just happen? or was i dreaming?
It's on the Dell website but it's $399.
if you can wait this monitor will go on special for $279 again
Do you know approximately how long?
Im guessing its better than the Asus?
Asus
72Hz (better FPS for GFX?)
5ms
Dell
60Hz
8ms (maybe more ghosting?)
dell has extra screen height being 1920x1200 vs 1920x1080
8ms is fast enough imo not many people can notice ghosting at that speed
So its 1.5ish inch extra height and 2 extra, closer USB ports + portrait mode Vs Built in speakers and a closer headphone jack + pretty design
Oh that pretty design... And I guess the speakers can give my ears a rest from headphones.... Oh that pretty design
Hope 1080 isnt too widescreeny
I was kinda looking at this bc the specs are crazy good:
asus
but its not 1200.
The Acer GD235HZbid looks cheaper and has high refresh but hard to find.
Edited by gamble
I took the dive, there was only 1 Asus left (In my location, I'm pretty sure there was at least 3 a few weeks ago) and who knows when the Dell will drop, I've got the money, so I snatched it.
It was on "preorder" so have to wait for it to arrive at their store.
I asked them about the dead pixel warranty and the sent me here: https://www.asus.com/Monitors_Projectors/MX...upport_Warranty
There seems to be a few different warranties for different models
ZBD - zero bright dot
PA Series - ?
Non-ZBD
Just not sure which mine falls under
just got this in today.
0 white pixels
0 black pixel
I think the aspect ratio needs adjusting tho, the bottom of the display is not even touching the bottom of the screen. same goes for the edges.
Anyone know how to do this? i've looked through all the monitor button options, the closest thing was OSD which only changed the position of the monitor menu/setup :/
maybe i cant change this... and if thats so, then this is false advertising:
(Made a pic) Posted Image
Though the monitor back light IS the display as in the advertised picture, its just that windows needs to be stretched to fit it. Which im not sure can be done...
The monitor speakers are definitely over hyped in Asus's advertising. They sound very hollow and just general bad/low quality. my netbook laptop speakers shit all over them, as im sure every netbook's probably would. Though this was expected from the reviews i read, if not i thought they might of been a little more clearer in the treble. Very hollow, mostly base which isnt even base.
edit: 0 black pixels, it was just dirt lol (silly me)
it should only be smaller like that if the resolution is below the monitors native
In control panel it says its 1920x1080. When i change it to 1680x1050, it fills the screen out.
hmm...
fixed it.
CCC > My Digital Flat-Panels > Properties Digital Flat Panel > Enable GPU scaling. (not sure if this was necessary)
then
CCC > My Digital Flat-Panels > Scaling Options Digital Flat-Panel > set Overscan to 0%
Thanks again Dasa
Now to change it from 60hz to 75hz if only it gave me that option, i wonder why its not showing up
I assume you're using a hdmi connection. I have no idea why, but using HDMI will mean you need overscan whereas dvi it doesn't, happened on a few monitors I've used with hdmi.
I fixed it, thanks guys.
I am using hdmi (from monitor) with dvi convertor (to gfx card). This is the cord that came with the monitor.
I fixed it by changing the scaling in the gfx card program CCC.
Its not giving me the option to go above 60hz, that i can find in CCC and desktop settings. Would this be because the cord isnt hdmi on both ends?
I know the monitor is capable of either 72hz or 75hz
