Camsie
Unlocking a "Read Only" USB Flash
Does anyone know how to unlock a flash drive that claims to be "read only"? Before you ask, no, there isn't a phsyical switch on the drive to set it to read only.
The drive we're having problems with used to be a regular USB flash drive. But now it claims to be read-only and I can't even format it or repair it with scandisk. I think the problem started when it was plugged in to my dad's old laptop when it went to blue-screen with a critical memory failure - pretty much the red flag that told him it was dying and he needed a new one. I think whatever glitch occurred while the flash drive was plugged in must've triggered some deep internal setting in the drive that switched it from a read/write drive to a read only one.
The data that was on the drive at the time is completely accessable and seems to be intact - we just can't change the drive's contents in any way. Does anyone know how to get deep enough into the drive's configuration to undo whatever's been done to it?
Only two things MIGHT save you.
The HP USB format tool. Its the closest to a true low level format you'll get on a windows machine:
http://www.softpedia.com/get/System/Hard-D...rmat-Tool.shtml
The other would be to run the U3 tool over it. If it was originally a U3 drive, its poissible the normal partition got fuxed, and only the u3 remains, and this what you're seeing.
http://u3.sandisk.com/launchpadremoval.htm
If thosedont work, try this guide
http://www.rmprepusb.com/tutorials/54---ho...protected-disks
