Kung Fu Hung-Su
What typing training have you undergone?
http://www.codinghorror.com/blog/archives/001188.html
Was just looking at this, and decided to check up how fast my typing speed was. 68wpm. I'm a self taught touch typist, that is, I was a hunt and pecker up until I just a few years ago (a very fast hunt and pecker, mind you) and decided to just put my fingers on the keys where they "should" be, and I was able to transition to touch typing very quickly.
68wpm is still pretty mediocre though. Just looked at the Typing Racer game linked in that article, and just saw some guy score 211 wpm. Holy crap.
What kind of typing speeds can you guys muster? And what training have you undergone, if any? Anyone use Dvorak or other keyboard layouts? Type with one hand or two? Prefer laptop jeyboards to desktop?
Edited by Kung Fu Hung-Su
I find my typing speed depends, to an extent, on the tactile and audio feedback. I like a clicky keyboard :). I don't think I'm a touch typer in the traditional sense. Though I never look at the keyboard I don't keep my hands in the appropriate position and use the recommended fingers for the recommended keys, as taught in my grade 8 keyboard skills subject. I got a VHA in that, topping the class. Suprised the heck out of the teacher because prior to my geeky self, it was always females that excelled at typing.
Last I looked, which was grade 8 typing circa 1989, I typed at around 65-70 wpm. I've probably sped up since then, but then, the old athritis might be slowing me down now :p I remember sitting in the labs at uni typing out code and a fellow student leans across from directly oppoiste me and asks "WTF. are you just bashing keys or something." astounded the speed of the noise I generated actually resulted in proper words and command being entered into the computer.
Typing speed is not that important though. As developers we spend 99.5% of our time thinking about code , rather than typing it into a machine. A hundred lines in an 8 hour day wouldn't be unacceptably low amount.
This is something I'll have to try out. I'm a very quiet typer.
Really? That's unreal...it was us geeks topping the typing games we had to play in grade 8, but that's also some 11 years later in 2000 =]
I agree completely. =] Might talk more on that in another topic though xD Edited by Kung Fu Hung-Su
Ha well there ya go 54wpm with 1 mistake. I typed the second word (upon) starting with a capital.
EDIT: Using http://www.typeonline.co.uk/typingspeed.php
Got 66 wpm with one mistake: misspelling "prostitution". Probably would have been higher if I didn't correct mistakes as I wen't along.
I should try with my clicky keyboard attached.
EDIT: I don't touch type in the classical sense of the method. I just know where all the keys are and type without looking. None of that home row crap I just know where everything is.
Edited by r4nd0m
I can touch type very slowly (about 15 wpm), my hunting and pecking is much faster (40-60wpm).
I still glance at the keyboard form time to time, I suck at transcribing because of it, and because it's not the way I'm used to working of thinking-->typing - hence the variation between about 40 (transcribing) and 60+ wpm (thinking)
I used to try and go for the touch typing technique, but l always got pissed off with the slow progress while learning, and found that my hands got sore given code's excessive use of punctuation etc.
30 wpm (no errors). I can't really go much faster without making lots of errors. I'm always going backwards to fix errors.
Edited by Jeruselem
I learnt to touch type while I was at school. But your typing speed transcribing has nothing to do with typing speed when your coding.
Also any decent coder (or command line junky) knows that the tab key is your best friend. Still you need an acceptable level of typing skill.
Ctrl + Space, for the microsoft junkies :)
My computer reports that on average (over the 6 months or so that I've been at this job) I type at 95wpm. Last time I was tested I typed at an error-adjusted 90wpm.
I've always preferred a clicky keyboard with a bit of travel - feels more like you're doing something. Having said that, I think I'm faster on a lower-travel, softer keyboard even though my hands are sorer after extended typing sessions.
I went to a week-long touch-typing workshop around Year 9 or 10. By the end I was certain that I would just go back to hunt+pecking but as it turns out I'm using those skills to this day. Has been a life-saver and is very cool to be able to type without looking at the screen or hands.
EDIT: my little finger is always hovering close to the Backspace (Delete on a Mac) key. I make plenty of errors!
I'd like to learn DVORAK, and I've been practicing my numbers and characters. I already know a few but I want to get 'em all, especially the rarely-used ones in the middle.
EDIT2: Hmph. Only got 79 wmp (100%, thanks bakcspace key!)
Edited by thesorehead
Did typing at school, and while my technique might not be perfect, I do alright. I use backspace a lot, but instinctly when I know I've hit the wrong button.
From the test linked on that article I got 63 WPM with 100% accuracy, but only because of th eability to hit backspace. I never understood tests that wouldn't let you backspace, because without that ability I stumble, and pause while I gather where I should be.
Heh. Consistently hitting 68-70wpm at home... keyboard differences perhaps.
76WPM with 2 mistakes. I do in the 80's on a good day and when I don't have to deal with foreign place names :P I find that's a bit slow though, I'd like to improve on it.
I did a touch typing elective in year 10 but then a big Maori kid broke my wrist in PE just right after we'd learned all the letter key positions (before the accuracy/speed training) and I never bothered to train my self properly since. Although been thinking about it lately. Found a fairly decent open source program called Klavaro (available on Linux and Windows, which is handy cause I promised a friend I'd find something).
I stick to the traditional home key positions etc, although I find the American system of reaching for the number keys on the same diagonal as the letters is insanely uncomfortable. I ended up altering the number key fingers to maximise comfort, as it turned out what I ended up with wasn't too far off from the system they teach in a lot of European countries (see the diagram on this page for what I mean: http://pl.wikipedia.org/wiki/Pisanie_bezwzrokowe ).
Anyway, if I was ever going to switch layouts I'm not sure if Dvorak is the way to go. I think the Colemak layout looks better, both because it's got an even lower average finger movement distance (surprisingly also for Polish as well as English) and because it's a lot more similar to QWERTY (in particular it preserves the location of a lot of common windows shortcuts: ctrl+c, ctrl+x, ctrl+v, ctrl+a, ctrl+z). The only thing I'm not sure about is the total removal of the Caps Lock, but then given the frequency of use it's probably better mapped as some sort of AltGr combo anyway.
I was looking at colemak as well =) I like the new position of the backspace key =D
Dave, I too have been using computers since I was 4. How old are you though? xD I'm 22 =)
Computers weren't invented when I was 4 :p
I've been actively programing since Logo Writer in grade 4. If you can call that programming :p
I got 64WPM, 100% accuracy, Dvorak. I don't think of myself as a quick typer, but I don't think I'm slow.
I switched to Dvorak about 12 or 16 months ago. I now can't type qwerty, but for the times I have to use someone else's computer, it only takes 30 seconds to switch layouts on Windows or Mac, so I don't find it inconvenient. The only downside of not being able to type qwerty is that my geekpoints are -- on other people's keyboards until I add Dvorak layout.
I didn't replace keys on my keyboard; I'm using an Apple Aluminium bluetooth keyboard with the standard US qwerty layout. Instead, I learnt by setting my wallpaper to a tiled image of the dvorak layout, as well as having a printout next to me when I was using a fullscreen application.
I don't miss qwerty at all, however I think it's a myth that Dvorak is faster. It does feel more comfortable though.
Edited by wilsontc
The best way to learn is to get a aluminum keyboard, rig some electrics up to it so that when you hit a wrong key you get a shock, then remove all the painted on letters.
Then, type.
Then, type.
You mean like the Das Keyboard Ultimate? =P
I type like a retard. I know where all the keys are, but I don't type the proper way. I've recently decided to change this and learn properly.
hehe. I've noticed I have a tendency to type like a retard too. I tried to type that properly and it was soo slow .. . fast hunt and peck atm.
Should really get around to learning to type properly . .that creeped me out. . .trying to type without looking at the keys. .. . .god dammit it's become habitual.
I too have been using computers since I was 4 (28 years ago (Sinclair ZX81, typing on those were remarkably annoying, they made the ZX Spectrum's rubber keyboard seem ergonomic)), and was never formally trained/taught how to type. I stopped looking at the keyboard when I was around 9 years old, and coincidentally took a high school typing class for easy credit at around age 15. However, I was too impatient to slow myself down to get into the habit of using the "proper" touch typing method, so never really learned it. I type with only 6 fingers for A-Z, use my left thumb for space and use my "pinkies" only for shift, control, alt, etc.
As for speed: I typically score 80-100 wpm on typing tests. The highest I've ever scored in a five minute test is 120 wpm, but I believe I can type considerably faster if making up the text as I go along rather than copying from an unfamiliar source. Since I timestamp IRC, I've observed that I've responded to lines on IRC at over 160 wpm at times.
Accuracy is usually 100%, since I do not believe it's fair to consider it a mistake if you have to backspace, as long as you actually correct it. If I'm copying something I will only look at what I'm copying and rely on tactile feedback to detect mistakes. If I'm typing something from my brain I'll just look at the text as I go. Correction with backspace will affect the typing speed so it is fair and practical. However, I'd say I need to backspace to correct a typo about once every 10 words on average if I'm typing as fast as I can.
...I'm still waiting for the programming relevant portion of a thread that could otherwise have been in General :p
Well, the original post quoted this url http://www.codinghorror.com/blog/archives/001188.html. It argues that fast typing is of critical importance to programming. I disagree even though I can type fast. People spend way more time thinking than typing when programming, so it doesn't become a major issue. If anything, slow typing is an advantage because it means you're more likely to think before you type.
