smakme7757
Any GPU better than GTX670 with 2x 6pin connectors?
As the title states: Any GPU better than GTX670 with 2x 6pin connectors?
My current PSU - Corsair CX500 only has 2x 6pin connectors. I was looking at picking up a GTX 780, but i don't have the 8 pin connector. I had actually forgotten that i swapped out my 850ax which went into my server. So I've only got the CX500 in my gaming PC.
Anything worth looking at?
not really
swap your psu with the server? or get a new one
or maybe use a adapter but i wouldnt like to especially if your tempted to overclock the gpu
not really
Yea pretty much what i thought.
I'm not sure i can switch the PSUs. The CX500 doesn't have enough SATA connectors. It only has 5 and i need 12. I'm also not sure if it would handle startup when all those disks will start spinning up?
If i need to buy a new PSU i might just wait until after xmas.
it should handle it with a 38a single 12v rail and 4 molex aslong as it doesnt also have a high end gpu but im not sure i would like to run that amount of data on a budget psu with chinese caps even if it is a very good one
