spankdmonke
Building a PC for Mum
So shes only going to use it for the internet, Microsoft Word stuff and printing. Something around $400-500
Im thinking of starting at the Brains, i dont want a too slow of a machine, whats a zippy CPU good enough for this? Intel and the AMD equivalent?
i might make it a mini tower
Edited by spankdmonke
something like this from the parts guide make sure you go with a ssd not a hdd since you want it to be zippy
Office Updated 5/11/2013
CPU/IGP/MBCeleron G1610 2.6GHz 2MB $44 + ASRock H71M-DGS $49 - OR - Pentium G3220 3.0GHz 3MB $69 + ASRock H81M-HDS (front usb3) $68
RAM 1x4g 1600 $41 x2 $82
HDD Toshiba 7200RPM 500GB 3Y $55 - OR - SanDisk Ultra Plus 128G $99
DVD DVD rw sata $18
PSU Corsair VS350 $39 - OR - SeaSonic 350W OEM V3 Gold $69
CASE With 120mm fan ~$39+
TOTAL $285-444
This one -> Pentium G3220 3.0GHz 3MB at 54wTDP it should stay nice and quiet without the cripple effect of a Celeron.
Was going to suggest an intel NUC but they are a bit outside your price range, especially the NUC-BLACK-120GB-W8
http://www.staticice.com.au/cgi-bin/search...B-W8&spos=3
but it is complete except for monitor and external optical drive.
Also only 3 USB ports which means after wired KB and mouse you only have one USB port free (unless you use a USB hub to expand them).
a nuc may be a good option but it would have to be a much slower celeron to fit the budget
the celeron above isnt to bad but this one is half way to a atom http://www.cpu-world.com/Compare/910/Intel...eron_N2820.html
http://www.staticice.com.au/cgi-bin/search...YKH+&spos=3
this i3 4010u nuc would be nice but a little over budget
Intel D34010WYK NUC Barebone $369
Crucial 4GB (1x4GB) DDR3 1600MHz SODIMM $49
Samsung 840 EVO Series 120GB mSATA $129
Astrotek 3Pin C5 Power Cable $9
http://www.pccasegear.com/index.php?main_p...oducts_id=25803
Thanks for the awesome response. I need to build this quick cause she need it soon.
I came up with this, using what was available on the umart site, and what i thought was good along with the most popular choices/reviews:
Intel i3 4130 $137
Asus H81l-Plus $109 (This is the cheapest mini mobo instock)
G skill 4GB (2x2) CL9D-4GBNQ DDR3 1600MHz $59 (review said: has no cooling fins, good for mini tower) Maybe Corsair is better?
Case: Antec ISK110 VESA Mini-ITX Case 90-watt adapter , 2 x 2.5" internal drive bays, Included VESA mount (she likes this one from what was available) $88
Samsung 120GB SSD 840 EVO (damn, intel out of stock) $109
Samsung SATA Black Internal DVD/RW Drive $21
SeaSonic 350W OEM V3 80Plus Gold PSU $69
=$592
So far:
Not sure if i3 is overkill, im leaning to no?
Not sure what the diff is between Asus H87I-PLUS $134 and Asus H81l-Plus $109 but im thinking the $109 one is fine.
Not sure if the case comes with a PSU and if Seasonic even fits the case
Not sure about PSU wattage, seems 350 is fine by your posts
Not sure if i should choose Corsair Ram instead.
Not sure if everything goes together.
I think her budget is ok at 600ish
I just realised how tiny this case is and that its got its own PSU and Seasonic probably wont fit
Will its own PSU be enuff for what i have?
she probably wont notice a performance difference between the pentium and the i3 so it may be overkill
its probably sufficient but the intel nuc looks to be a better quality package
so from umart http://www.umart.com.au/newindex28.phtml?i...&sid=143383
Intel BOXD34010WYK $345
G.Skill 4GB DDR3-1600 1.35V SODIMM F3-1600C9S-4GRSL $58
Samsung mSATA 120GB SSD 840BW EVO $135
Astrotek AU Wall to C5 Power Cable 3pins to Mickey Plug 1.8m $5
$543
using another pc you can install the os from usb but if she needs odd you will want a usb external
Ok so i have to add those parts into the NUC?
I cant see where you found these:
I found these tho:
Intel SSD 120GB 525 Series, mini PCIe, mSATA 6Gb/s, 25nm, MLC, read/write speed 550 MB/s, 500MB/s $159
G.Skill 8GB Single Channel DDR3-1600 SODIMM [sQ] F3-1600C10S-8GSQ $89
or
Corsair CMSX4GX3M1A1600C9 4GB (1x4GB) Vengeance Performance Memory Module DDR3 1600MHz CL9 SODIMM $59
The Corsair says its for 2nd generation... the intel box is 4th gen, does that matter?
I think ive decided with either this or the NUC above:
CPU: Intel PENTIUM G3220 3.0GHz/3MB CACHE/LGA1150 $75
MOBO: Asus H81M-E 2xDDR3 PCI-E 2xSATA3 2xUSB3.0 DVI D-SUB $64
RAM: G Skill 4G(2x2G) DDR3 1600Mhz PC12800 9-9-9-24(CL9D-4GBNQ $59
SSD: Samsung 120GB SSD 840 EVO SATA III 6Gbs $109
PSU: SeaSonic 350W OEM V3 80Plus Gold PSU $69
CD/DVD: Pioneer SATA DVR221L Black OEM $25
CASE: NZXT H230 USB 3.0 White Mid Tower(NO PSU) $89
$490 Or the NUC? $599
that will be better than the nuc just much bigger and use a bit more power
change the mb with a usb3 header so the front usb3 ports on the case will work
ASRock H81M-HDS $64
take a look at this case if you want to save some cash
Silverstone Precision PS09 Black Case, No PSU, 2x USB 3.0 $49
it has sound deadening and filters
Done! Thanks Dasa!
I wont switch the case tho, it has a pre-order status (cant wait, plus ill throw in some $ for her bday)
She'd prefer a mini case but it was just too much for me to take in with the limited stock and understanding.. (frikkin PCIe/mini PCIe, SO-DIMM/U-DIMM, ATX/ITX/mini ITX/Micro ATX ahhhhh!!)
She was going to buy a $545 with worse parts (1333 Ram, 500GB HDD, etc.)
Awesome! Thanks again guys!
a lot of things come with no power cord these days
trying to be green\cut costs
most people have a bunch of them laying around since there the same power leads that have been used for pc\monitors for at least 20 years now
hahaha im so stupid. I Found 1 :D
Windows Experience:
CPU: 7.0
RAM: 5.9
GFX: 5.8
Game GFX 6.5
HDD: 7.9
Forgot to add power to DVD and SSD in these pic, figured that out when it didnt work.
This thing flies with that SSD, have to get myself one.
This wifi card would go with the mother board yes?
Yep plug it in to the short PCI Express 2.0 x1 Slot just above the white H81M-HDS lettering.
Any wifi card will.
I recommend a USB one by TPlink, they work every time for me, and being USB means you can use a LOOOONNNGGGG usb cable if reception is an issue. Otherwise, its a long antenna cable, which is significantly more expensive and problematic.
k thanks, i tried putting mine in from my PC, it didnt fit maybe its not express (PCI)
Most likely a PCI card as they are by far the most common. PCI and PCI Express (or PCI-E) are not compatible in any way shape or form.
