Ishta2000
Quick and easy way to check RAM is not dead or bad.
Hi All,
I have been having issues with infrequent BSOD like once a month if that for example.
I have narrowed it down to the RAM causing the issue but I cannot figure out which stick of RAM it is.
I have two 8GB of Corsair Vengeance RAM and can't tell which is the faulty one.
I have tried both separately and everything works fine but I know its the RAM because I have some spare 2GB sticks of RAM that I am currently using and have had no BSOD with them.
Any suggestions?
FYI I ran memtest and found the dodgy culprit. Not really worth buy 1x8GB stick though so will use 2x4GB sticks that I have for now and then upgrade later on.
Thank you for the help.
