TazDCassar
Faulty Drive?
Hi, Just would like to know why my computer keeps crashing when playing games, as my games are installed on the F Drive and I can't defrag the F drive all the way (It stops at about one third of the way? Or is it the graphics card? As I have used Furmark to stress test the graphics card and it worked fine. Thanks.
Could be any of a 1/2 a dozen things, but the defrag does suggest a drive problem.
Need a lot more info, but start with a full checkdisk as described here
http://www.howtogeek.com/howto/windows-vista/guide-to-using-check-disk-in-windows-vista/
Applies to XP, Vista, 7 and 8.
If the drive is large (1Tb or bigger) this can take 7 or 8 hours so set it to run overnight if possible.
If the PC is more than a year old also check for dust blocking the CPU cooler and video card cooler, causing an overheat shutdown.
