AMD Zen
On 1/6/2019 at 11:51 PM, SceptreCore said:
Come on Dude... that's a silly excuse. AMD's GPU drivers are top notch. Besides which you won't need them with an AMD CPU.
Yup. I very rarely come across issues caused by AMD drivers from the last 10 or so years. Hardware wise the biggest fault I had in that time was an Intel CPU
I wonder what Intel could do if they removed the graphics part of their 1151 CPUs or removed the extra PCIe lanes from the 2066 CPUs.
They have removed the IGP... or deactivated it - in the new iX-9X00KF CPU's. But they won't net much more performance I should think.
High performance CPUs really don't need a IGP since they'll be paired with a high end GPU anyway.
Possible it helps with cooling a bit, probably not dramatic.  They can use these chips that have failed in the igp and not waste them, should help some with inventory woes.
  • Yes Sir! Very atomic! 1
3 hours ago, Jeruselem said:
No big Zen 3 announcement at CES so ... keep waiting!
Well I should think not. We're waiting on the big Zen 2 announcements.
The AMD keynote should start in another 4 hours. But I'll be stuffed if I'm staying up till 1-2 in the morning to listen to the reveals.
Yea some are calling it Zen 3 launch being 3000 series or 3rd iteration/release... definitely not confusing lol
Bound to happen. But I blame the Tech media. It's their job to get this right and they get bamboozled very easily. They sometimes call the series Ryzen, Ryzen 2, Ryzen 3. ?
Edited by SceptreCore
  • Confused 1
https://www.anandtech.com/show/13829/amd-ryzen-3rd-generation-zen-2-pcie-4-eight-core
Blink and you miss it: AMD's keynote address this year was a whirlwind of primetime announcements for the company. The message is clear: AMD is committing itself to 7nm as the future process note that will drive the company's innovations starting in 2019. The first consumer products on 7nm will be the Ryzen 3rd Generation Desktop processors, using Zen 2 cores, offering more than competitive performance against Intel's best hardware. Also on the docket is a return to high-end graphics performance, with AMD set to release a 7nm graphics card that can spar blow-for-blow with the competition at the $700 price barrier.
AMD at CES 2019
One of the odd things about AMD’s announcements this show has been the tale of two halves. Normally a company will push out single major press release with everything in it. This year AMD discussed its news around Ryzen-3000 series mobile parts and AMD Chromebooks just as the show started, and we were all confused if this was going to constitute what was in the keynote or not – it would seem odd, after all, for the company to pre-announce its keynote announcements. Luckily, AMD has plenty to announce, and it’s all pretty juicy.
First up, CPUs. AMD presented its next generation 7nm desktop CPU, which is the 3rd Generation Ryzen.
Attacking the Mainstream CPU Market: Toe to Toe with Core i9-9900K
Ignore everything you might have heard about what AMD’s future desktop CPU is going to be. Here are most of the details you need to know.
The new parts, codenamed Matisse, will be coming to market in mid-2019 (sometime in Q2 or Q3). The processor the company had on display was made from two pieces of silicon on the package: one eight-core 7nm chiplet made at TSMC, and a 14nm input/output chiplet with the dual memory controllers and the PCIe lanes, made at GlobalFoundries.
AMD%20CES%202019%20KEYNOTE%20PREVIEW%20S
The company did state that it is the world’s first 7nm gaming CPU, and will also be the world’s first mainstream CPU to support PCIe 4.0 x16. At this time the company is not commenting on if the 3rd Gen is going to have a maximum of eight cores, or if this represents the best processor of the whole family.
Because the processor is still far away from launch, frequencies are not being finalized yet. However, the processor is for the AM4 socket, given that AMD has previously said that it intends to keep backwards compatibility for several generations. That will mean that this CPU will work in current 300 and 400-series AMD motherboards.
What this means for PCIe 4.0 is actually fairly simple. We expect there to be a new line of motherboards presumably something like X570 that will be PCIe 4.0 compatible, for any new PCIe 4.0 graphics cards that will be coming to market. One of the differences with PCIe 4.0 is that it can only handle PCB traces up to 7 inches before needing a redriver/retimer, so these extra ICs are needed for ports lower down the board. But, the first PCIe slot on most motherboards is in that limit, so it would appear that a lot of current 300 and 400 series motherboards, assuming the traces adhere to signal integrity specifications, could have their first PCIe slot rated at PCIe 4.0 with new firmware.
Going For Die Size
As we can see on the die shot above, the 8-core chiplet is smaller than the IO-die, similar to the 8+1 chiplet design on EPYC. The IO-die is not exactly one quarter of the EPYC IO-die, as I predicted might be the case back the Rome server processor announcement launch, but it is actually somewhere between one quarter and one half.
Doing some measurements on our imagery of the processor, and knowing that an AM4 processor is 40mm square, we measure the chiplet to be 10.53 x 7.67 mm = 80.80 mm2, whereas the IO die is 13.16mm x 9.32 mm = 122.63 mm2.
+15% Performance Generation on Generation, Minimum.
During the keynote, AMD showed some performance numbers using the new Ryzen 3rd Generation (Matisse) processor. The test in question was Cinebench R15.
Our internal numbers show the 2nd Generation Ryzen 7 2700X scores 1754.
This new 3rd Generation Ryzen processor scored 2023.
This would mean that at current non-final clocks, the new parts give a 15.3% increase in performance generation on generation. Cinebench is an idealized situation for AMD, but this is not at final clocks either. It will depend on the workload, but this is an interesting data point to have.
Identical Performance to the Core i9-9900K, Minimum.
Our internal benchmarks show the 9900K with a score of 2032.
The 8-core AMD processor scored 2023, and the Intel Core i9-9900K scored 2042.
Both systems were running on strong air cooling, and we were told that the Core i9-9900K was allowed to run at its standard frequencies on an ASUS motherboard. The AMD chip, by contrast, was not running at final clocks. AMD said that both systems had identical power supplies, DRAM, SSDs, operating systems, patches, and both with a Vega 64 graphics card.
At Just Over Half The Power…?!
Also, in that same test, it showed the system level power. This includes the motherboard, DRAM, SSD, and so on. As the systems were supposedly identical, this makes the comparison CPU only. The Intel system, during Cinebench, ran at 180W. This result is in line with what we’ve seen on our systems, and sounds correct. The AMD system on the other hand was running at 130-132W.
If we take a look at our average system idle power in our own reviews which is around 55W, this would make the Intel CPU around 125W, whereas the AMD CPU would be around 75W.
This suggests that AMD’s new processors with the same amount of cores are offering performance parity in select benchmarks to Intel’s highest performing mainstream processor, while consuming a lot less power. Almost half as much power.
That is a powerful statement. (ed: pun not intended)
How has AMD done this? IPC or Frequency?
We know a few things about the new Zen 2 microarchitecture. We know it has an improved branch predictor unit, and improved prefetcher, better micro-op cache management, a larger micro-op cache, increased dispatch bandwidth, increased retire bandwidth, native support for 256-bit floating point math, double size FMA units, and double size load-store units. These last three parts are key elements to an FP-heavy benchmark like Cinebench, and work a lot in AMD’s favor.
As the Intel CPU was allowed to run as standard, even on the ASUS board, it should reach around 4.7 GHz on an all-core turbo. AMD’s frequencies on the processor were unknown; but also they are not final and we ‘should expect more’. Well, if the processor was only running at 75W, and they can push it another 20-30W, then there’s going to be more frequency and more performance to be had.
The one thing we don’t know is how well TSMC’s 7nm performs with respect to voltage and frequency. The only chips that currently exist on the process are smartphone chips that are under 3 GHz. There is no comparable metric – one would assume that in order to be competitive with the Core i9-9900K, the processor would have to match the all-core frequency (4.7 GHz) if it was at the same IPC.
If the CPU can't match IPC or frequency, then three things are possible:
  1. If the TSMC process can’t go that high on frequency, then AMD is ahead of Intel on IPC, which is a massive change in the ranks of modern x86 hardware.
  2. If the TSMC process can clock above 5.0 GHz, AND there is room to spare in the power budget to go even higher, then it’s going to be really funny seeing these processors compete.
  3. AMD's Hyperthreading for software such as CineBench is out of this world.
TL;DR = AMD’s 3rd Gen Ryzen Processors Are Another Step Up
When speaking with AMD, their representative said that there will be more information to follow as we get closer to launch. They’re happy for users to discuss whether it is IPC or frequency that is making AMD the winner here, and they’ll disclose more closer to the time.
Ian, I Thought You Predicted Two Chiplets?
Naturally, I assumed that AMD would be presenting a Ryzen-3000 series desktop processor with sixteen cores. For me, and a lot of others, felt like a natural progression, but here we are today with AMD only mentioning an eight core chip.
I predicted wrong, and I've lost my money (ed: in Las Vegas no less). But if we look at the processor, there’s still room for a surprise.
There’s room for a little something extra in there. There’s not much room for a little something extra, but I’m sure if AMD wanted to, there’s just enough space for another CPU chiplet (or a GPU chiplet) on this package. The question would then be around frequency and power, which are both valid.
There's also the question of lower core count processors and the cheaper end of the market. This processor uses silicon from TSMC, made in Taiwan, and GlobalFoundries, made in New York, then packaged together. We have heard some discussion from others not in the industry that this makes cheaper processors (sub $100) less feasible. It is entirely possible that AMD might address that market with future GPU.
What AMD has plans for in the future, I don’t know. I don’t have a crystal ball. But it does look like AMD has some room to grow in the future if they need to.
4 hours ago, Jeruselem said:
So Ryzen 3 is work-in-progress-because-we-don't-want-f-it-up-again product
Well... If it's not finished... It's not finished.
Hasn't even been a year since Ryzen 2000. Not sure what you mean by 'f-it-up-again'
Alright guys...
Why are we not discussing this -possibly mid-range - Ryzen 3000 series 8 core part, that is not final silicon, that is not final clocks, slightly beating a 9900k in Cinebench at about just above half the power draw?
This is astonishing!
You can see this is where the other CPU/GPU goes...it's got the lanes there ready for it.
added video
 I guess for me because it's ~6 months away but still it's looking like being a great chip and I have enjoyed re4ading through the info you provided.
  • Thanks 1
What makes you say that?
What makes you think that running some code in the IGP vs an external GPU is going to be better, power or time wise?
AMD: “No Chiplet APU Variant on Matisse, CPU TDP Range same as Ryzen-2000”
One of the big questions coming out of AMD’s CES announcements was if its new CPU design, codenamed Matisse and which enables two chiplets and an IO die on a single package, would support one of those chiplets being graphics based in order to make an APU. In our discussions with AMD, we received confirmation that this will not be the case.
The new Matisse design is the platform for AMD’s next generation of desktop processors. The layout shown at CES this year represented the design as having a single IO die, about 122.6 mm2 and built on GlobalFoundries 14nm, paired with a chiplet die, about 80.8 mm2, containing eight cores and built on TSMC’s 7nm. There is obviously space on that package for another CPU chiplet, and there has always been questions if the chiplet design is amenable to using a graphics chiplet instead.
AMD stated that, at this time, there will be no version of the current Matisse chiplet layout where one of those chiplets will be graphics. We were told that there will be Zen 2 processors with integrated graphics, presumably coming out much later after the desktop processors, but built in a different design. Ultimately APUs are both mobile first as well as lower cost parts (usually), so different design decisions will have to be made in order to support that market.
This doesn't rule out a future processor using chiplet graphics, this is just for Matisse.
Our contacts at AMD also discussed the TDP range of the upcoming range of Matisse processors. Given AMD’s definition of TDP, relating to the cooling performance required of the CPU cooler, the range of TDPs for Matisse will be the same as current Ryzen 2000-series processors. This means we could see ‘E’ variants as low as 35W TDP, all the way up to the top ‘X’ processors at 105W, similar to the current Ryzen 7 2700X. We were told that the company expects the processors will fit within that range. This should be expected on some level, given the backwards compatibility with current AM4 motherboards on the market with a BIOS update.
It would probably be better for games and programs like photoshop if that space was used for a l4 cache rather than extra cores but that wont happen.
Like a stack of HBM?
If they could get the latency low enough sure.
