grifter
Building my first ever computer.
Hey all,
Thanks so much for making me feel welcome in my Green Room "hello" post.
So, I really want to build a top notch gaming PC.
This came on after really enjoying playing games on my MacBook Pro. So I want to go deeper and discover what it's like to play games with max settings in the comfort of my own little battle station/home getaway zone. Sounds like a really enjoyable hobby that isn't "blowing heaps of money at the pub".
I have no experience in the tech side of computers (or tech anything else), so I'm greener than the Hulk. Although Bruce Banner would know how to do this in an instant!
So far, I've worked out what I think are the steps to PC building success:
Step 1: Research all the parts I need and work out if they play nicely together.
Step 2: Work out where to buy them in Australia, then surrender my wallet.
Step 3: Put it all together.
(Step 4: Instantly plan next build.) ;)
I've heard this video is one of the most helpful:
I've watched it several times, and I'm still confused about how he knows what to plug in where. And do you need to buy all the cables separately?
Also, it seems like a bit of a lucky dip that the components you buy will fit in the case you choose. Or, are they rather universal slots?
And for picking parts, should I just browse forums and read recommendations?
Thanks for coming along with me on this one guys. Will post pics and all the rest as things progress.
Edited by grifter
this one goes for close to two hours safe to say i havent watched it but it comes recommended for those that want extra detail
with cases & mb there is eatx atx matx itx
middle two are most common
some cases list a limitation for hsf height and gpu length otherwise there fairly universal
Not usually. All of the cables required come with the parts, your power supply (PSU) will have the cables required to power all the other parts. The plugs will match up to the receptacle on the part you are powering, pretty hard to stuff it up.
The slots on the motherboard are, as long as you take note to buy the right RAM (DDR3 or DDR 4 etc depending on the mobo), same goes with the CPU, you need a socket 1156 motherboard for a socket 1156 CPU. etc. If you get a large video card then you might have trouble getting in to fit into a smaller case, ask here, or google or ask your retailer if the the parts you want to order will all fit together.
Decide what you want, (gaming, video editing or just web browsing/ desktop work), decide on a budget and then ask for advice. You'll get parts recommendations that you then research from there.
Thanks for the replies guys!
So I had an easy day today and attempted to put some parts together that I think seem like a good fit.
I'm guessing that the top results on PCPARTPICKER are the most popular?
What does everyone think?
http://au.pcpartpicker.com/p/wZvHvK
Was trying to get a CPU cooler that had the thermal paste pre-installed.
Not sure about the case, wondering if it's too small? (Actually, not sure about everything! But they seem like quality parts.)
Edited by grifter
Big spender eh? :)
I'm not up on current prices sop can't help you there but 1) is 500gb going to be enough storage for you? 2) Note that the new nvidia graphics cards are due out fairly soon so you might see some discounting on the GTX-980 or spend the same amount on the new hardware when it arrives?
you want at least a 3000mhz c14\c15 ram kit not a huge deal but it will improve cpu performance ~10% in games and costs very little extra
you could save some cash on the mb dont get me wrong its a nice mb for those that want to tweak there system but ~$200-250 gets you a decent mb
corsair h100i tend to be loud and dont really perform any better than a big hsf like nh-d15 provided the case has good airflow
new gpu should be out next month that are as fast as the 980ti but cheaper and use less power they should also perform better in dx12
AMD are bring out a dual Fury X (overpriced) and nVidia are releasing the GTX1080, so prices should start moving down to get rid of old stock.
The Intel 6850K is also coming out soon.
its already out
$2199 https://www.pccasegear.com/products/35347/xfx-radeon-r9-pro-duo-8gb
amd is also releasing Polaris around june with any luck
r7 460 to r9 490x which should compete with gtx1080 and 980ti performance
https://www.techpowerup.com/222156/amd-radeon-r9-480-non-x-performs-close-to-r9-390x
"Fury X" - WTF. Nice ripoff, did they ask Kingston if they minded that they stole their "HyperX Fury" branding?
Big spender eh? :)
Maybe I am being a bit full on, but I always spent around 3 to 4K on my laptops, so thought I'd just put that amount of cash into a desktop. Overkill?
I thought 500gig would be okay to start, then I can upgrade later. But maybe that's a pain and I should just do it all now.
Also, thanks for the warning about the new graphics cards.
Sounds like I should wait a few months... BUT I REALY DON'T WANT TO! :(
Okay thank you mate.
I'll have to some research as not sure what those numbers mean in relation to RAM.
Sounds like I picked a dud CPU COOLER, will keep looking. Was kinda trying to find one that didn't require me putting on thermal paste.
And is the new GPU you're talking about the new graphics cards mentioned above? Thank you for your time.
Okay thanks. Maybe I could still get the graphics card I picked, but for a much cheaper price if I wait for the new stuff to come out.
Edited by grifter
500 Gig total storage won't go far for modern gaming. Some games these days come in over 50 Gig installed. Plenty more use over 10.
its already out
Polaris is the new GPU/graphics card everyone is mentioning?
Also, what does the 1080 and 980 mean? Is that the speeds?
1080, 980 - just model numbers.
But with graphics cards the model number usually gives a clue to the capability. The system they use has been fairly consistent for years, used to be 4 digit numbering system but is now mainly 3.
e.g. old numbering system HD4870 (ATI/AMD) 8800GT (nVidia).
new system R9-380 (AMD) GTX750 (nVidia).
First number in both cases is the series/generation. Tends to be cyclic going from 0 to 9. New series releases are anything from 6 to 24 months apart.
Second number is the important one, refers to capability within the series. 0 to 3 is low end stuff. 4 to 6 is midrange. 7 to 9 is high end.
Last number/s often just zero, usually used to distinguish among variants of a particular model.
With comparing inter-generational cards from each company. A 2 generations old high end card will often be similar in capabilty to current midrange card. But it's not consistent. Sometimes a "new" generation will just be a process size shrink with little else changing other than less power usage and heat generation.
Thanks, this is really helpful.
So what does everything think, keep researching yet hold off buying until the new graphics cards are released? Or, stuff it and go ahead, as you have to jump in at some time and the GTX980ti will still beat out the new Pascal stuff for some time anyway?
Edited by grifter
Rumours are nVidia pascal GTX1080 and GTX1070 will be released in May. I got no idea with AMD Polaris.
Have you got an old video card you can use in the meantime?
you wont see anything much faster than 980ti till next year just cheaper and more efficient so if your happy to pay the premium go for it
to give you an idea of what the ram numbers mean
the higher the frequency the faster the ram but it has to be balanced with timings where the lower the better
all the numbers in the middle here are a rough calculation on the performance difference between them
for example 2133 divided by 12 =178
the real world difference it makes is only evident when a game is cpu bound as faster ram improves cpu efficiency it doesnt help the gpu which has its own memory
Nope. Just a very old MacBook Pro :D
And thank you DASA, that's very helpful.
With regards to price, how much do video cards generally drop when a new one comes out? Are we talking a dramatic drop straight away, or a gradual drop the older it gets?
Edited by grifter
sometimes they dont drop in price
this time its not so much the 980ti that will drop in price but the new cards being made should offer similar performance at a lower price point
initial prices ore often still high though if there is low stock
I'm also a little confused about power supply.
How do you know what wattage you need?
And is the difference between gold, platinum, and all the other ratings a gimmick?
Also, if you get an M.2 SSD, should you just put the operating system and a few games on it? With most of your other games on a regular SSD?
Thanks guys.
Edited by grifter
the typical 1151 system with a single gpu will use ~300-400w maybe ~500w with a very high v oc too high for 24\7 use
so a 550-650w psu is plenty for most people pccg has some xfx psu that are very good value in that power range
there is some other good units about
gold to platinum is just a small jump in efficiency its nice to have but the power savings are not likely to cover the outlay with the current price difference
most m.2 ssd are still limited to sata speeds
there is a few overly expensive ones like the samsung 950 pro that can make use of it but for most software\games sequential read\write speeds are not the limitation so you only gain 1-2sec from the ~3000mb read speed
Thank you.
So it sounds like it's best to stick with a regular SSD at the moment. But maybe I should just get two of them so I don't run out of space.
If the top results in PC PART PICKER are the most popular (are they?) then the one listed below should be good for my setup?:
http://cplonline.com.au/evga-supernova-g1-650w-psu.html
Also, is the motherboard I've chosen (Asus MAXIMUS VIII HERO) overkill, as I won't be using M.2 now, and I'm only running one graphics card? Or, good idea to start with options to upgrade later on?
Not worried about spending money (as this is replacing a very unhealthy and expensive habit), but also don't want to waste money.
Thanks heaps guys.
Edited by grifter
unfortunately the evga 650 g1 isnt very good quality for its price where as the 750 g2 is
its a nice mb that is good for tweaking the most out of a oc but if you wanted to save some cash its a good place to do it
Gigabyte GA-Z170-D3H $209 as you can see this one is a lot cheaper while still providing decent features
you can get a large single ssd at a decent price
SanDisk 960GB Ultra II $368.50
im using one of these for my games drive with a old 64g ssd for the os at the moment
Early leaked benchmarks for the GTX1080 look good, the GTX1070 might be the go.
Thank you mate, I'll look into the 750g2 instead.
just wondering, why do you have your games and OS on two separate SSDs?
Is this the latest version video card? Is it still "Maxwell" or "Pascal"?
Thanks for the tip!
Edit: just did some reading and discovered it's the latest version using "pascal".
Just wondering, would this mean I'd have to rethink everything else I was planning on getting, like the cooling and such? Thanks guys.
Edited by grifter
