Soulessdeath
Ethernet Mechanical switch
Hi guys im in need of a solution for switching between 2 Ethernet cables with the ability to switch 2 in 2 out basically i need to be able to disconnect either at any time with the press of a button. Its for switching between 3G internet and satellite internet and to have different firewall setups on each line. Anyone have any ideas on how to accomplish this?
You can do this in the Windows "view network connections" - right click on in the connection and disable/enable it.
network-connection-status-for-network-ad
Edited by Jeruselem
Yeah, That wont work for what i need to do. Its going on a network with about 10 other devices and PC's and i need to firewall each connection with different permissions and have the ability to have one or the other connected at the push of a button. Going on a fishing boat and the skippers are not that smart so one button is what i need to keep it to.
Only real on/off switch for LAN cables is to pull them out or connect them, they are designed to run 24/7.
Something like https://www.amazon.com/CableWholesales-Way-Switch-RJ45-Female/dp/B004Y34VQS
or
https://www.amazon.com/MT-VIKI-Network-Splitter-Selector-MT-RJ45-2M/dp/B00DRG1SLO
Otherwise all I can think of is a dual WAN router which may allow different firewall rules on each WAN connection.
This is going to be a major issue for equipment longevity given the highly corrosive environment.
or
Given connectors are really "gold plated" - the copper in sea environment goes bad pretty quick if exposed to salt water.
or
Yeah i know the corrosion issues all too well, this is my 3rd year in the industry. The network splitters are what im looking at but they are only 2 in 1 out really need 2 in 2 out. I can draw up a map of what i need to do and put a picture up later. Lets just say i cant do set ip's and the devices see each other as terminals and try to connect to the wrong spots, as such i need to keep each connection apart so 1 or the other connected to the network at one time, So that i can set different firewall rules for each connection. I may end up having to build them myself if i cant find a ready solution.
You talking things like this?
http://www.ebay.com.au/itm/2-Way-2-PORT-RJ45-AB-Manual-Switch-Box-1Gbps-CAT6-CAT5E-CAT5-selector-Phone-NEW-/301195658865
Otherwise there is a LOT more out there.
Have a look on ebay for "Manual Ethernet Switch"
http://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.Xethernet+manual+switch.TRS0&_nkw=ethernet+manual+switch&_sacat=0
Hope this helps!!!!
Would you be able to explain in more detail why a software solution isn't possible? with USB NIC's or cards, how is this 'better'?
Not being cynical, I'm just wondering what use case this is the better option for?
So The way this is working is, Theres 2 terminals on the network the satellite phone terminal and the 3G internet terminal, Now as both are running on the one network the satphone interface program on the PC in use picks up the 3g modem instead of the Satphone terminal and so you cant use the satphone and 3g at the same time as they just get confused where to connect. There is also a VOIP handset on the network which plugs into the satphone terminal and now this also gets confused as to where to connect.
The next issue is we have TPLINK routers which we are using to set firewall rules as to what they can and cant use on the internet but we want to be able to set different rules per device and dont want to do this on a ip basis or mac address as we are after reliability and power surges and such are very common on the boats which means that at any given time the power can drop out and we have had instances where this causes ip conflicts. (not very good when a prawn trawler is 200nm away from port with no other form of communication)
There is also up to 5 PC's on the network and then there is also our NMEA 0183 to UDP converters aswell as the satellite phone and 3G modem. Which means on most things it is quite hard to keep valid ip's as some dont support set ip adresses. The manufactureres of the equiptment know of the issues but are not interested in fixing them and as such we try to come up with a most reliable solution to prevent as much as possible down time as possible.
I will find the network map and upload it to show, Someone else may have a better way of doing it, but from experience a software fix has never worked for us, or the other companies which are trying to solve this issue.
Im not in your field, so I wont pretend I know what yoru job demands (I hate when people tell you 'youre wrong' and havent done it first hand).
However, with 0 experience (I'm a network engineer, but Ive never had to rely on it for marine comms).
Your first issue should be able to be solved by making sure the METRICS for the connections are correct.
The second issue should be EASILY avoided using Static IP's. Just set the critical stuff 'high', like 192.168.1.199. If the single boat has 199 devices on board using DHCP, there's probably a party going on :P
the third not accepting fixed IPs is a pain, but you can map Static IP's OUTSIDE the DHCP range.
So your converters will get a 'dynamic' IP each time, with little to no risk of conflicting with the devices that DO allow static.
For example:
DHCP 192.168.1.100~192.168.1.150
Static PC : 192.168.1.151
Static VOIP phone: 192.168.1.152
and so on.
Just something to mull over, but its an interesting use case that's for sure.
My father is a boat builder by trade, but all the ones he manages at most use a satelite phone, and a digital radio (with backup analogue radio). There's no fear with IPs. lol.
Bit of a image to show what is going on in the network.
I have to make seperate firewall rules for the satphone and the 3g modem for when they are acessing the internet as satellite internet is not cheap ($700 1GB).
Im no network engineer just learning as i go, So going into deep network configuring is beyond me at this point thats why i was looking to a mechanical system. Satphone works fine when no 3g modem present and 3g works fine when no satphone present.
Makes some sense, but what I said above still actually applies to what you've explained.
Its probably worth finding a managed services provider, even if its only once, and having them come on site and show you how to simplify your system.
Your method will work, but also relies on human error being controlled, and you know what they say "they'll just make a better idiot"
I can understand wanting to physically disconnect satelite. But as for the rest of it, an hour or two with a network professional should have you understanding how that works :)
Hell, when I'm not at work I'll help however I can for free, for fun.
Its a field ive considered getting into, but here in QLD, since my father was a boat builder in his younger years.
Just a word of caution, everything is going through that one switch - have an identical backup switch as well switches are fragile when a UPS died and took out the switch connected to it,
If you were able to splash out for something a bit more fancy than a TP-Link NAT box (maybe a used Cisco 800 Series), you would be opened up to the option of raising/lowering network interfaces in software. Though you would need to find somebody willing+able to configure it for you.
So then you'd have a shortcut on a computer that you double-click to "toggle to 3G"/"toggle to SAT" or whatever.
BUT THIS...
I LOVE THIS!!!
Edited by SquallStrife
If you were able to splash out for something a bit more fancy than a TP-Link NAT box, you would be opened up to the option of raising/lowering network interfaces in software.
BUT THIS...
I LOVE THIS!!!
Of course you do :P
or
Just need to flash bios
or
Bot \ Spammer.
How would this help? What BIOS? Are you a knobjockey?
Oh shit. All this time we've been wasting effort on anti-fouling and cathodic protection, when ALL WE NEEDED TO DO WAS FLASH BIOS.
You've just single-handedly saved all maritime industries millions of dollars. Well done.
  • Haha 1
Been a while since i have been on here, i see things have started going the wrong way. We are currently building the switches ourselves and have also incorporated a timer circuit so that the satellite connection drops out after 5 minutes.
On 8/25/2016 at 12:52 PM, Soulessdeath said:
Decided to make my own, When switch pressed in 1 set of ports work and when switch not pressed other set works.
The only proper Atomic way - find your own solution.
  • Yes Sir! Very atomic! 1
