redrob
need a new GPU for my 3570k help
Assume that's R7-370 with a Core i5-3570K ?
Bit of a mismatch. I've recently gone to nVidia, AMD just seem to have fallen too far behind insofar as performance of equivalent cards in the range not to mention being somewhat more power hungry and hot running.
I just went a GTX 960 which should perform at a higher level than R7-370 though not by a big margin.
A lot depends on what you want to spend and if your PSU can feed the thing but something like a GTX 1060 at around $300 would give a worthwhile improvement.
Or maybe an RX-470 from AMD at around the same price.
2 Gig is becoming standard at mid-range and up, for single monitor 1080p probably more than enough but if you're doing multi-monitor and/or 4K res then more VRam would be a must. Though of course don't fall into the trap of low-end cards with ludicrous amounts of memory.
Sorry the i53570k is the psu
Intel Core i5 3750k Ivy Bridge Quad Core 3.4.GHz @ 4Ghz,Corsair HX 650 w ,Corsair H 100i Cooler ,R9 290 X 4gb ,ASUS MG279Q 27inch WQHD IPS FreeSync Monitor
XFX Radeon RX 480 GTR OC 8GB i was looking at one of these i need freesync dont i
Edited by redrob
You have that monitor? I guess then may as well get a decent card to be able to throw out the frames and resolution to do the refresh rate justice.
lol yes mate i lashed out when i sold my monster dell,so the one i chose will do the job
hey im of the track a bit but how the uck do you set up netflix on windblows 7 please cant seem to find any decent help on google
rx 480 is no faster than the 290 unfortunately so its a bit of a side grade shame your current gpu died
at least its far more efficient than the 290 and competes fairly well with nvidias 1060
I would suggest a GTX1060 graphics card at this point.
It'll handle absolutely everything you need at 1080p, and even go into Ultra HD with no real issue as long as you don't need everything on ultra settings
You could look into after market cards like the GTX1060 G1 Gaming for a little extra juice
So im confused again i thought the more GB the faster the card ,XFX Radeon RX 480 GTR OC 8GB
GTX1060 G1 Gaming this one is 3 GB ,and seems they make a 6GB as well .Can someone clear this up for me please
So i dont need a AMD card to get freesync
Bloody hell what do i choose theres so many roflmao
Edited by redrob
yes you do need a amd gpu to use freesync nvidia still refuses to support it pushing there more expensive gsync
you could just run adaptive vsync or fast sync if you have high fps but there not quite as good
extra vram only helps if you need it just like system ram having 128g is no faster than 8g if the games only using 5g
rx 480 on average is faster than the gtx 1060 at high res and in dx12 games
gtx 1060 is stronger in dx11 games at 1080p
the 3g gtx 1060 is crippled a bit so it is actually a bit slower than the 6g model
fairly sure the rx 480 4g is the same speed as the 8g but at 2560x1440 current games will be getting close to the max and it may not be long till that starts holding you back
mind you since the rx480 is no faster than your current card your probably finding the gpu itself is lacking in power with some games already so future plans probably dont really matter other than you may want a new one before long
Thanks Dasa
Thats my problem the xfx 290 that i had which died a few months ago i now only have the on graphics.so can you please recommend what i should buy .ive got about $400
$400 bucks won't get you in the ground floor on a GTX 1070, seems they start around $570. You'd get a 3 Gig or even 6 Gig 1060 with change to spare though.
Earlier on there wasn't much indication of your budget. Really it's up to you, the bottom line is eventually the card will be "too slow" so it comes down to capacity planning on your own part.
what model 290 was it? some have 3y warranty
if you need a replacement and your happy to get one with the same performance level as the old gpu
XFX Radeon RX 480 GTR OC 8GB $379
gtx 1070 was mentioned as its a large performance jump and a decent upgrade from your old gpu its just a shame that it doesnt have free sync and is out of your price range
https://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1060/26.html
Thanks Dasa i bought it of XEN and i dont think it would still have warranty would i really notice a great deal of difference if i safe another $200 and went with the 1070
well the witcher 3 would go from ~40fps to ~60fps but freesync apparently helps make things feel smoother so how much of a trade off that is i dont know
the other option i guess is another secondhand 290 there going for ~$150
up side half the price for much the same performance as a 480\1060
down side twice the power use and no warranty
may tide you over till amds next gpu becomes affordable
If you really want to go with AMD, you could just wait til early next year.
Rumors are coming out about the new cards, AMD wants to come back hard.
And if it doesn't, the other cards you're looking at now will probably be cheaper!
I'd suggest a 470 as a possible option, amazing bang for buck
I'd recommend a switch to Nvidia since AMD cards have kind of just been underperforming relative to Nvidia for a little while now.
If you can afford the 1060 that'd be best, but if not the 900 series cards are also solid!
+1 to this.
6GB GTX1060.
Why?
Newer games (like DOOM) require 4GB or more to enable 'max graphics'.
But on that note, a 1060, using the 'built in overclock sliders' will (almost) match a stock 1070, and still be cool, for $200 less.
Sure you can OC the 1070 too and walk all over the above scenario, but the money has to stop somewhere.....
i would go the rx480 8g over the gtx1060 6g at the same price even without a fresync monitor but with fresync already its a easy choice
futu online
Asus AMD Radeon RX 480 ROG Strix OC 8GB GDDR5 Graphics Video Card HDMI DP VR
20% off with code COMMIT20. Ends 22 Jan = $367.2
GTX 1060 vs. RX 480 - An Updated Review
with updated drivers it has caught up in dx11 and extended its lead in dx12
futu online
Is that due to performance?
I was a fan of the 1060 because I thought they had quite a lead on the VR performance (future proofing a little)
there isnt much info on vr performance but your right it doesnt look good for amd
for vr gtx 1070 should really be the starting point anyway
a overclocked gtx 1060 getting a 30-35% boost to close the gap on 1070 performance? on what ln2?
i have my 1070 on water and overclocked to 2100mhz core +800 mem with no dips from powertune thanks to a vmod and it barely nips at the heals of gtx1080 founders edition which is only 20% faster both at stock
i cant see gtx 1060 scaling much differently from being overclocked since it has a similar starting frequency and limit
all the VR tests I've seen bring them pretty darn closed OC '60 vs Stock '70.
In game can still leave a gap, but 1060's OC'd get well over my required 75fps\hz for gameplay.
I guess I just accepted 1060's were "more than good enough" for all current titles on MAX
