redrob
azrock az7 extreme 4 3 short beeps
At start up i am now getting 3 short beeps ,according to the chart this indicates Main memory read / write test error ,does this mean my ram is on its way out,it does it 3 times then boots fine
You run any memory testing tools?
Run mdsched from Windows - it's a built in Windows memory testing tool (unless you're running something else).
One page I found mentions base 64K test failure. You could try swapping the Dimm positions but it'd probably make no difference since multi-channel Ram configs interleave addresses.
few things that may be worth a go
reseat the ram
update bios <if latest try reset it
try one stick at a time
I'd bet your motherboard battery is flat (the little CR button cell).
I bet it's forgotten it's ram timings, and trying 3 defaults before it finds the one that boots :)
Just an educated guess.
Whack a multimeter on the battery.
Thanks guys seems it was just a simple reseat and all beeps gone cheers everyone
hmm though the problem had gone but on start up today just one set of 3 beeps.grrrrr what size voltage is the round battery please i cant read it on mine
Most likely a CR???? battery but you'll need to read the cr number. Most common is the cr2032.
3 or 3.2V
I put a new 3v battery and am now using 1 stick instead of 2 as 2 wont boot anymore,it boots with 1 but still get the 3 beeps.
Do i need to change some bios settings
Edited by redrob
i seem to get the 3 beep sequence 2 or 3 times then it boots,
Edited by redrob
Yep changed the settings in bios ,but it won't boot now with both sticks ,when it boots with 1stick it beeps about5sets of 3 then it boots to windows
sounding like a mb problem to me if each stick on its own is ok
bit more serous than Nich's problem so extra v and tweaked settings probably wont be enough to fix it but then it should be quicker to diagnose since you dont have to run hours of tests just to duplicate the error
tried the other slots?
reset the bios and drop the ram speed to 1333 if it isnt already
Thanks Dasa yes mate ive tried the other slots and can only seem to boot from the first 1 ,both sticks are from the same kit ,cant even boot to bios now
ok so im in the bios now it finally worked
ok dropped the dram to1033 still beeps no change
sounds like your mb is toast to me since its fairly rare for the cpu to go
may be worth removing everything from it reseating the cpu and running it on a box of the igp with a spare psu if possible just to be sure its not a usb device or something weird
ok thanks mate no spare PSU here when i blow em up they go to the bin ,might just get another mobo i guess cheers for you help
Looks like I'll be selling some Shit to get a new rug cheers for everyone that has helped me
