g__day
Simplest way to display local IP JSON data as a spreadsheet / html page on my PC?
So some major progress - I now have 1) admin user id and password - and have been shown how to use Excel 2013 with PowerQuery add on - which reads javascript really well!  I can now query the old or classic views of my device - with the admin user id, or the new views using PowerQuery and if the URL is not protected all is fine.
My Dilemma
If in Excel I simply select Data -> From Web and supply the URL User Id and Password – it works fine – but it returns javascript which Excel simply can't natively ingest.
If in Excel I select Powerquery -> from Web, it asks basic or advanced. If I chose basic – it only asks for the url and this fails. If I chose Advanced – I don't know how to format the query to supply the user id and password. Which is annoying given Powerquery natively does support Javascript and easily converts it into readable tables!
If in Powerquery I try and reach say http://envoy:011842@192.168.0.12/api/v1/production/inverters the call will fail and bring up web access – where I can choose API, Simple or web access – and for simple or advanced I can add user id and password – but the call simply hangs.
Does anyone know how to use Excel 2013 with PowerQuery on a web access call to supply the user id and password?
Many thanks, Matthew
