Mysticizm
1050 or 1060 for Battlefield 1
Ideally you don't put cards near the hot GPU, the other cards aren't as heat tolerant.
In the bios, try and find options for "Spread Spectrum" and try to enable, or disable them and see if it changes anything.
It sounds like you're battling electro magnetic interference, which is meant to be fixed by spread spectrum, but can often be made worse....
This fixed it., It was either that or a bad OC.
I found in the bios options for increasing the CPU power from 100% 120% 130% 140% for OCing.
I changed it to 130% even tho i used asus MB auto OC you think it would of changed that itself.
Enabled Spread Spectrum
Works properly now, ty
(Edit: there is still a buzzing noise in the sound when i play games though, from sound card being too close to gpu i s'pose)
Edited by Mysticizm
Probably.
You can eliminate that risk by buying and testing a cheap external (USB) soundcard :)
I think you should be better off with GTX 1050 only as you can play BF1 on high settings with it.
1050ti at least!
Why did you bump such an old thread?
And where would you recommend we purchase one from? MSY?
