cleadge
Home Theater help
ok so here's the deal.. we currently have a Sony STR-DE597 receiver the only thing which it is missing is an active subwoofer.
as far as i can tell from its back pane and user manual it requires a sub with a mono input, this is where i am having issues finding a suitable sub
as all the ones i have come across use a L/R input as opposed to a single input.
or would it be fine to use a 1xRCA to 2xRCA cable
If anyone has any recommendations it would be appreciated.
Edited by cleadge
you can use any sub, it doesnt have to have a single mono 'channel'. lfe doesnt have left and right effects. just buy the sub you want and hook it into the left channel.
