gamble
Viotek 32" 1800R Curved 1440p 144hz Gaming Monitor
I just ordered this monitor... Seems like a good deal but havent ever used this company before. 12hrs left on the massdrop:
https://www.massdrop.com/buy/49972
Model number: GN32LD
Panel Type: VA
Screen size: 32 in (81.3 cm)
1800R curved
Refresh rate: 144Hz
Response Time: 6ms
Overdrive Response Time: 3ms
Resolution: 2560 x 1440p
Display colors: 16.7 million
Display format: 16:9
DCR: 5,000,000:1
Preset settings: 5
FreeSync and Overdrive Technology
Connectivity: DVI, HDMI, display ports
Display Port Version: 1.4
HDMI Version: 1.4
Vesa Mount: 100 x 100
Stand: Height and Angle Adjustments
Dimensions: 8.1 x 28 x 16.6 in (20.5 x 71 x 42 cm)
Weight: 18.6 lbs (8.4 kg)
FreeSync range: 48 to 144hz.
With a curved VA screen, aren't you going to see noticeable fading towards the sides?
Looks like a VERY subtle curve.
And I'd expect it to actually FIX the fading on the sides, since the furthest point away is once again facing the user.
Honestly I'm not sure. I only have owned TN but the tv is VA. Was hoping it would be better viewing on VA for angles and color. Really looking forward to 1440p with 32" gaming :)
Oh it's VA, I don't know why, but when I saw Nich mention fading my mind just read "TN"; yeah the VA will be mint, don't even stress about it.
Really like this monitor. Much bigger than I thought now that it is on the desk. Using my 24" on the side for wattman and cpuid. Even though the curve is very minimal, it took a min to get use to it and adjust. Gaming it was total fine but in desktop/browser you need to have the tilt and height right for where you are sitting because for me it makes lines look slightly different, especially since I have a non curve right next to it. Color is much better and I know I can still tweak it some. The detail is surprising, in Ashes of Singularity, the ships have much more detail than I was able to see. Im not sure if that is because of the res or the size but now I can see like blue brains like things on the ships were before it was just mostly blue glow. Even when they fire at each of the color and much more it shows now particles. Maybe its Im just getting older and will need 40" in 10 more years...
Join me. 36" 1080p TV @ less than 1M.
Aren't "Quality" eyes just the best!
I never used this company's monitor so, that I am not sure about it that it is the good deal or not. I only used IPS panel monitor for gaming. But it is VA.
Why do you keep referencing that gamingbuff site?
Are you a new spammer we get to block, and a new website we get to blacklist!?
looks like a very nice value display for amd users
