barryalen1992 0 Posted June 4, 2018 In which occasion you should use a water cooler. How do you feel that if you would need one or not. Share this post Link to post Share on other sites
Rybags 1,162 Posted June 4, 2018 Camping. Walking on a hot day. If it's hot then you probably need one. Share this post Link to post Share on other sites
Chaos.Lady 199 Posted June 4, 2018 *sigh* Seriously. If spammers were less banal, they might be less likely to be instantly gotten rid of. *might* Water coolers are full of fungus as they are usually not maintained very well. Even the ones that use bottles, unless the pipes and fittings are cleaned regularly, will grow all sorts of interesting new life. Unless you mean those steel public ones which there is hardly any of around the place. They are ok unless the homeless have been peeing in them again. But if I'm thirsty and there is one available - sure I'll use one. :) Share this post Link to post Share on other sites
