stuub27
Sony NW-A45 Walkman & Sony Noise-Cancelling headphones
I recently bought one of these: https://www.sony.com.au/electronics/walkman/nw-a40-series
and am looking at buying either these: https://www.sony.com.au/electronics/headband-headphones/wh-h900n
or these: https://www.sony.com.au/electronics/headband-headphones/wh-1000xm2
Of course, they all require charging. Via USB. Either desktop or laptop. I only have a desktop.
Which is fine when I'm at home, obviously.
But I want to know if I can charge them using the wall adapter that I use for my phone?
Or even better, can I use the power bank I carry with me?
Now, I did ask Sony first. But they gave me the helpful answer of, basically- you can, but we don't recommend it. But they didn't say why. And I certainly don't know enough about electronics to understand.
Can anyone at least enlighten me as to why it would be a bad idea?
Thanks
OK, it's sort of something like this (I think BigCliveDotCom on YouTube explains it somewhere).
USB (forget 3.x here) uses 4 lines, + - and the data lines. + - carry the power.
A device can identify whether there's a computer at the other end or just a "dumb" power supply by fact that the data lines should be grounded if it's a power supply (or the other way).
But bottom line is that a device can identify what's at the other end and e.g. request more than 500 mA from a computer, or take more from a power supply.
The recommended thing for L-Ion type batteries is something like test extra amperage @ charging voltage until the wanted maximum is found provided no great voltage drop occurs.
Then charge at high amps until almost full. Then trickle for the remaining few %
Anyway - something like that. Some devices have good smarts and can just regulate what's coming in and cope with a meaty 2.5 Amp 5 Volt external battery.
Others are lesser equipped (maybe like headphones) and might only want 800 mA at 5 Volts max for the entire duration.
I suppose there's ways you could do a bodge - like make a dongle with current limiting resistors so a 2 Amp supply is reduced somewhat. Of course if you use a single resistor you're probably going to have heat issues.
Well, thanks heaps for that. Appreciated :)
I don't understand some of the technical stuff, but I get the general idea now, I think.
It's one of those times a USB power meter can come in handy - they're all over eBay for about 3-4 bucks each.
I'll look into that
