stuub27
Xbox 360 into 1920x1200 LCD monitor
Hi, got everything hooked up- the PC, the 360 (via HDMI) to the Samsung 2493...
I ask: should the picture from the Xbox, set at 1080P, cover the whole screen, or should it be 'letterboxed'?
At the moment it fills the whole screen, and seems maybe a bit stretched...?
How can I fix this (if indeed it needs to be fixed)?
Thanks
Stu
PS I've searched around a bit for the answer elsewhere, but my brain doesn't cope well with too much stimulation (as in hooking everything up etc) and am failing at finding answers :(
Any assistance will be MOST appreciated!
I used to run my 360 into my 24" LCD and let it scale to fit the whole screen (16:10). Never really bothered me.
If your monitor has the option to set the scaling to 1:1 pixel mapping, you'll get a 1080p display with black borders at the top and bottom.
Cheers- that's what I thought...
Now all I have to do is figure out if it does 1:1
(And yeah, as you say, letting it fill the whole screen is not a big problem)
Hmm, computer says "no"...
Well, the dude I spoke to at Samsung said no 1:1, will stretch from Xbox
Still, it really is a SMALL issue- looks great anyway! Was more curious than anything
then to keep the ratio, switch to a 16:10 ratio.
OK, I may be being REALLY dumb here...but what exactly do you mean?
For PC (via DVI), resolution is set at 1920x1200 (native; works fine)
For Xbox (via HDMI), the only resolution options are 1080P (and backwards)....as far as I know, I don't have the option to set the Xbox 'ratio', as such...?
Please enlighthen me on how I do that...???
he's using a hdmi cable, so im assuming it only allows 480P, 720P, 1080P etc
using a vga cable will probably allow 16:10 resolutions, 1440x900, 1680x1050 etc but these resolutions will probably look like crap since they're not native
Have you updated your Xbox at all?
I'm sure that it allows for more resolution customisation once updated.
THIS^
Hmmm, you mean I have to figure out my Live connection?? Bugger :P
Setting up live is as easy as plugging in an ethernet cable. I don't understand how it can be difficult for anyone, least of all someone who visits here.
Depends on one's home network set up
But anyway, got that sorted :)
But guess what? Still stuck with screen issue- think it might be HDMI causing the 'grief'...or, just as likely, I'm missing something still!!!
Fair enough. Can you go to component? That's what i run and i can take my pic of standard resolutions with no letter boxing.
Have component cable...no component inputs on monitor... :(
Anyway, let's put this thread to rest. As long as I sit further away (now I need an extension for/new headphones) the vision is pretty damn sweet.
Sincerest thanks to all who offered advice. I appreciate it muchly :)
Stu
