deuce_23
help with overclocking ram
I have over clocked my system i have a foxconn black ops mb x48 e8500 cpu over clocked to 4.2gzh no prob water cooled. The problem i have is the ram it says its 1333mhz ddr3. it would only recognize it as 1066 i have manage to set the ram divider to 1:2.6 and i get 1184mhz ish out of the ram, Any higher and it wont boot If i set the divider 1:3 i get 1333mhz but wont boot How come i cant get the ram to 1333mhz all the ram timings are set to auto. I have tried increasing the voltage.
its crossair 1333mhz ram
Please help
Increasing the voltage is good, but are you running it at what it's specified for?
Ive up the voltage i havent touched the timings i left them all on auto but it should run stock 1333mhz
have i just purchased crappy ram i paid about $115 for 2gb ???
I wanted to go faster but for the extra cash the performance gain sucked ass
what reason would it have gone to 1066mhz when i first installed it.???
so should i go through the timings and tweak? why cant i get 1333mhz with the timings on auto??
Run CPUz and see what the SPD data says.
Good modules will have 2 or 3 sets of speeds/timings.
You might have more luck if you set the timings manually in the BIOS.
Or, you can leave them slack and use MemSet within Windows to alter them.
Jeez, overclocking RAM and timings in BIOS for my setup = failcat ...
The only way I can really adjust the timings with my RAM overclocked is with memSet.
I think the RAM is fine, it might be the motherboard instead though (possible solution directed towards deuce_23 and myself :P). Well that is the punt I am taking because if anything the RAM seems to be fine in my opinion.
Would it be silly of me to ask if you have a spare set of DDR3 RAM on you or another DDR3 motherboard to test this :P
