clockworkman
acceptable SNR and attenuation values
i tried searching for this question, but didnt find an answer, and the forum search appears to be a little bit fucked here, so please forgive if this is a done to death question.
basically, what is an acceptable range of values for Signal Noise Ratio and Line Attenuation on my modem for adsl2+
i dont know how far it is to the exchange
regards in advance
regards in advance
This might help you. It's a calculator that uses your Attenuation to calculate possible ADSL1 and 2 speeds:
http://fremnet.net/article/216/adsl-theore...peed-calculator
This is a graph of speeds vs distance:
http://www.internode.on.net/residential/in...e_adsl/extreme/
kind regards scootre, that was very helpful
Attenuation (dB) you should be getting a value of about 35 for a average distance/connection from the exchange.
note that your Attenuation (dB) is Zero at the exchange. an ADSL/BDSL line will fall over at about 55dB.
also very helpful :)
thanks
im currently getting about ...
Parameters
								Downstream					   Upstream
SNR Margin				10.5 dB							  9.5 dB
Line Attenuation		 33.0 dB							  23.0 dB
CRC Errors 					0									   0
Latency					 Unknown							 Unknown
Upstream 	977000
Downstream 	6847100
Edited by clockworkman
Don't go saying scary shit like that :-p
Noise Margin:     6.5 dB                         21.0 dB
Output Power:    19.5 dBm                        12.0 dBm
Attenuation:     55.5 dB                         31.5 dB
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          3776                0           384                 0
