Smokie
[Worklog] Building Aluminium Case From Scratch
Thanks for all the positive feedback!
MedicineBaby Posted Today, 10:01 AM
Hey Smokie, where did you get your Aluminium sheets from? Because I have an old MSI case missing side panels, and would like to try and do a case to it.
I got is from metals R us in toowoomba. They only sell it per square meter so if there is excess they charge you for that as well. Fotunatley for me it worked out well that i only had a little bit left over at the end. Google 'metal suppliers' with the australian search on (if you live in oz) and have a look at the ones in your area. As you wont need much i would suggest going there and ask if you could grab a bit of scrap as they are bound to have some the right size for you.
-Smokie
Dude, thats briliant! Looks wicked aswell. Bit of sprey and she will be apples!
EDIT: didnt see that picture, Satin black. Nice. Everything is better in black!
PS: what kind of paint did you use? not the shade I mean was it sprey? or you paint it? or did you whip out the compresser?
Edited by Avliden
Avliden Posted Today, 04:43 PM
All the paints i have used are white knight and was applied via a spray can, no compressor ; )
-Smokie
I havnt been feeling like sanding so i have set to work on a couple of other things. My parts came so i set off modding my Graphics card.
My new parts:
Unfortunatley they sent me the wrong handles so they will be getting exchanged.
First off, pull the GPU appart.
Now to add the fan addapters.
Here are a few shots of it all put together.
I have also painted AL onto the side of the case as it is the chemical symbol for aluminium.
Stencil.
Finished product.
I couldnt wait to see the temps on my modded cooling so i set it all up.
Cant get better ventalation than that i recon. My temps at idle use to be 55 to 60 degrees now idle is 40 to 45 degrees. I am very impressed with the outcome here.
I have also painted the PCI slot covers and drilled holes as well to provide more ventalation (can never have enough).
Primed.
http://i43.tinypic.com/73hr8i.jpg
Painted.
http://i44.tinypic.com/2ebeqmt.jpg
Enjoy!
-Smokie
Wishin' I had a pic of an Army Arctic Heater unit. You keep on puttin' holes in that thing and it's going to wind up lookin' just like one... :-P
I have no idea what and Army Arctic Heater unit is but i am assuming it gets shot up fairly well lol.
-Smokie
-Smokie
Good one! I could prolly empty a mag into it and not hit it one time ... supers wouldn't be impressed tho...
Placed an order today. Paying for it tomorrow that it takes about 5-7 weekdays for it to get here. The right case handles will be getting posted with it as well.
I think the Hyper 212 was the best valued HS at only $46. Opinions?
-Smokie
The CPU cooler i wanted was not in stock afterall so i had to change my order. For a little more at $55 i got the Thermalright HR-01 Plus. Unfortunatley it does not come with a fan. I am not planning on attaching one. I think my case will have enough ventalation and air flow to keep ot cool enough without the need of a fan on it.
-Smokie
The last thing i should be doing is considering my next build let alone moddle in in CAD. O what the heck! Here are some rough pics. I have plenty more in mind to do to this moddle before it is good enough to consider building.
It is a bit confusing, i think i have it over cluttered and need to cut back and make it more simplistic while still keeping its looks. Anyway what do you all think?
-Smokie
Tiny little update... Been sanding but no one really wants to see heaps of pics of that lol. Went to the local computer shop for a chat and walked out with 5 free thumb screws :D saved myself about a $1 there!!! These will be used of the swinging side pannel instead of the standard screws i am currently using.
-Smokie
Got back to the old sanding and pollishing this arvie. Got some shot of the results for you.
Sanded:
Pollished:
Reflection:
Alot more to do yet though.
-Smokie
Edited by Smokie
shame you put so much weight on the drill, and nothing to support the panel, when you were drilling the fan-screw holes - try a lump of wood underneath, and let the drill do all the work.........make sure the drill bits are nice and sharp too.
what he ^ said, I always use a block of wood when drilling to stop things like that happening although the case still looks pretty good.
Yeah it does annoy me a bit. I never thought of using a block of wood. I will hopefully do a better job with the two 120mm holes. Once the fan grill goes on over the top the indents shouldnt be seen as easy. Well i hope so anyway. I was thinking of painting the OEM fan gills that are going on. Should i leave them silver or paint them the midnight blue or the satin black? I am leaning towards painting them satin black. What are your thoughts?
Yeah i am leaing towards satin black as well. It will be a while until my order comes though. A few mates wanted to get some stuff so i had to make another payment yeasterday and that will clear tomorrow morning than give them a day or two to process it; i wouldnt expect it out here until late next week. My original order was $108 now it s $450 lol. O well. Im making a bit of money out of it.
-Smokie
Chrome is the slilver right...? So that paint does not flake you apply a Self Etching Primer and than the colour. I tested it on a 80mm grill and the paint set very firm. It would be super sweet if i could get sponsored for this build. You see a heap of others get sponsors by big companys like OCZ, Coolmaster, AC Ryan and you just drool over the stuff they get. But i can keep dreaming.
-Smokie
Edited by Smokie
I'm not sure why you have intake fans on the top.... Hot air rises, remember.
Other than that, this is sure forming up to be a tough rugged case if nothing else. :P
SquallStrife Posted Today, 12:42 PM
Thanks. I have been thinkig about that i was wondering if having them as an exhaust would be benifical... Would in interfeir much with the incoming air form the front 3 120mm fans?
-Smokie
